6 Speed Swap
Old Aug 7, 2014 | 07:26 PM
Red94z28's Avatar
Default 6 Speed Swap
Hey guys I have a 1994 z28. Its original transmission is the 4l60e. Ive searched in and out of these threads and cannot find the answer to my question. I have every part I need to swap in my t56. The question I have is I know you need to retune for the tachometer and speedometer,and other parameters, but will I be able to start and drive it without a tune? Thanks!
Old Aug 7, 2014 | 08:24 PM
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Just swap the PCM to a t56 one, probably easier. I think it will run and drive but the computer might not like that :P
Old Aug 7, 2014 | 09:22 PM
When you say you have all the parts do you mean you have the T56 PCM and wiring harness?
The speedometer needs to match up with the rear and tire size the PCM is programmed to. The transmission would have no effect. I have no idea why a transmission change would have any effect on the tach?
Old Aug 7, 2014 | 10:33 PM
Red94z28's Avatar
I have the t56, the hydraulics, pedal assy, new clutch, pressure plate, flywheel and all the necessary pigtails. My car is already tuned for my 383 thats currently in the car now, so I couldn't just throw a m6 pcm in it.
Old Aug 8, 2014 | 08:07 PM
So you are going to have a check engine lite because the computer can not detect any of the transmission connections/inputs. You are going to have to do some wiring for your reverse lights. You are also going to need to add a safety switch so you can not crank the car with out clutch pushed. I assume you are just by pass your current safety switch.
Again as long as the speed sensor is plugged in I do not see why the speedometer would be an issue.
DiElSleL
Mar 8, 2012 01:23 PM
quick78
Oct 3, 2011 11:12 PM
383 Coupe Car
Mar 1, 2010 12:51 PM
84VarinZ28
Oct 4, 2007 04:37 PM
Shmack2004
May 27, 2007 07:02 PM
