6-speed swap?
Old Apr 19, 2011 | 03:49 PM
quick78's Avatar
Default 6-speed swap?
I am looking to ditch the old Saginaw 4-speed and put a t-56 6-speed in instead. Will a 6-speed out of a LT1 camaro bolt in, can i get the shifter in the right position, has anyone done it, and what all will I need to do it? The Saginaw will be lucky to survive a day behind the new engine so I need to get on this cause spring is just starting way up here.
Old Apr 19, 2011 | 10:54 PM
Yes, it's been done. No it's not a bolt in. You'll need a different bellhousing, and crossmember, or at least modify the crossmember for the T56. You'll also need to get as shifter to adapt it to sit in the right location. You'll need to change to a hydraulic clutch master and slave also.Tremec and others sell kits to do a complete swap.
Try the search feature here and you'll see some posts from a few guys who have done the swap. It's not cheap, nor easy, but it's a great swap if you've got the time and money.
Old Apr 20, 2011 | 12:32 PM
quick78's Avatar
Well I am just looking for a cheaper alternative to Keisler's $3100 set up for there RS- 600 5-speed don't get me wrong that is a good deal for what it is, but it just doesnt fit into my budget.
Old Apr 20, 2011 | 07:41 PM
If you look around the T56 5 or 6 spd. will generally run around $1200-$1500 alone for a good used one. If you get all the other pieces you'll have that much more in the swap. Then you'll have to start modifying and fitting it all to work.
Here's a link to the swap that Car Craft did:
Tremec TKO Transmission Swap - Car Craft Magazine
Here's another that JAM has at their site:
T56 Early GM
And here's the Weir kit:
A Hot Rod T56
Old Oct 3, 2011 | 11:12 PM
Nomad's Avatar
Know any good places to get a decent T-56 online?
Red94z28
Aug 8, 2014 08:07 PM
DiElSleL
Mar 8, 2012 01:23 PM
383 Coupe Car
Mar 1, 2010 12:51 PM
84VarinZ28
Oct 4, 2007 04:37 PM
Shmack2004
May 27, 2007 07:02 PM
