rough driving conditions
Old Jun 4, 2012 | 11:21 PM
chevyman510's Avatar
Default rough driving conditions
Horible goin over bemps n potholes.. Rough ride.
thinkn of replacing struts with kyb
Do i need to replace frnt n rear? As well as the shocks?
Old Jun 21, 2012 | 07:36 PM
Packerfans1's Avatar
I have the same issue, it has gotten a little better when I put 18" rims on it but still is a bit rough...
Old Jun 21, 2012 | 08:50 PM
You should replace both front and back, and if you are looking for a softer ride get something near stock. Also, ultra low profile tires, lower than series 50, will make bumps harsher.
As for struts or shocks, the car uses either one or the other, but not both on the same axle. So if the front uses struts and the rear uses shocks, that is what you need to replace. You did not mention the year of the car so you will have to figure out what it is using
csmiddy
67-69 V8 Tech
Dec 9, 2012 10:12 PM
Jmoney503
Nov 10, 2011 09:21 AM
CJ51974
Jun 1, 2009 08:59 PM
Bonnie w/2000 v6 called Roxy
Apr 4, 2009 03:19 PM
2fast4u
Dec 3, 2007 06:02 PM
