front suspension
Old Jan 16, 2011 | 11:22 AM
jfavaro13's Avatar
Default front suspension
i have a '96 camaro rs 3.8. there is a clunking noise when i turn to the right and it sounds like the strut or like the spring has gone bad. also one day i would like to have this be my project car and put a v8 in it and was wondering if i have to beef up suspension in the front or if it doesn't matter. thanks
Old Jan 16, 2011 | 05:16 PM
blackz87's Avatar
Sway bar end end link may have broken.
Old Jan 16, 2011 | 05:34 PM
could be ball joint, control arm bushings, sway bar ends or bushings, tie rod ends, get under there and have someone turn the wheel from side to side and see if you can see anything moving when it shouldnt. you would need another car the same yr with a motor and trany to use as a donor car, these cars are built motor and trany spacific so suspension, wiring, computer and trany would need to be changed with the motor.
Old Jan 20, 2011 | 09:45 AM
StoveBolts's Avatar
I'd take a look at the strut tower. When you turn the wheel, does it make a distinctive "pop" sound?
Old Jan 25, 2011 | 07:39 PM
roadkillracing's Avatar
if it clunks on a right turn also check the left front hub bearing.
phat69Camaro
Apr 17, 2014 02:20 PM
kenjames23
Feb 11, 2014 05:43 PM
Koryn
General Racing/Tech
Jun 2, 2008 02:59 AM
Koryn
Jun 1, 2008 04:03 AM
