Front Strut replacement ?
Old 03-23-2013, 01:53 AM
Z28Camaro98's Avatar
Well i dont suspect anything wrong with mine. I checked them and all my balljoints. all seem tight.
  #42
Old 03-23-2013, 01:56 AM
Originally Posted by jkeaton
I'll probably do the shocks/springs and bushings all at once whenever I feel like diving into that project. Not looking forward to that one.
Just do it man. haha The longer you wait the harder it will be because the rust gets worse. Worst case is that you just have to take your shocks/springs off yourself, then take them to the shop to have them remove the springs for you. But its tricky putting the spring over the new sohck, because you have to put the spring on in exactly the same place as the old one so the top mounts fits your mounting holes. I just made a mental note of where it was according to the bottom bolt holes, and had no trouble. You cant simply just put the spring on and then the top mount.... otherwise they wont fit!
  #43
Old 03-23-2013, 07:58 AM
jkeaton's Avatar
Originally Posted by craby
i was talkin to the op
My bad.
  #44
Old 03-23-2013, 09:24 AM
Randy Bilyea's Avatar
You can, actually.
If you mount the bottom of the shock in a vise (wrapped in a rag to protect it) and put a pry bar between the studs on the mount, you can spin the mount and spring on the shock base to get it to line up.
I had to do it with mine, as i didn't have them aligned right when I got it back from having the springs and mounts installed. It's pretty stiff, but it will move.
  #45
Old 03-23-2013, 04:40 PM
Ive also seen from a youtube video that if you lube up the bottom and top side that the spring fits in, you can spin it much easier.
spoonsol
02-03-2013 09:04 AM
coopdc78
04-19-2012 04:01 PM
JeepGuy12
10-12-2010 03:00 AM
rozellcoair
09-12-2010 09:32 AM
anthonys95
09-05-2010 01:45 PM
Quick Reply: Front Strut replacement ?
