4th generation stock suspension good?
Old Oct 29, 2007 | 09:55 PM
aleksandr's Avatar
Default 4th generation stock suspension good?
Hello.
I have a '98 V6 Camaro and am planning out a number of mods for it. One of the things I was considering was upgrading my suspension. Getting new adjustable coil overs and shocks. Now I was wondering if it is really worth it, or if the stock parts on the car are good enough for most situations. I am not a racer but I do like an intense ride and wouldn't mind taking my car on a track at least once in the near future. Are suspension mods a must for this?
Old Oct 30, 2007 | 07:22 AM
Nike Z28's Avatar
Default RE: 4th generation stock suspension good?
I had Qa1 a wile ago and now i have KYB AGX so now a know how crapy the stock shocks are
Its worth it!!
Old Nov 1, 2007 | 04:43 PM
aleksandr's Avatar
So which parts should I change? And what are some good replacements to look at? And how much will this all add up to be?
Old Nov 5, 2007 | 07:40 AM
Nike Z28's Avatar
I can rekomend the KYB AGX. You can have a nice soft ride on the street and then just turn the **** and you have great handling. I like them. Good price also.
Old Nov 5, 2007 | 01:24 PM
CamaroKid16's Avatar
Ill agree. I have eibach lowering springs with front kyb agx adj. struts, That was NICE to say the least. Then i added a 32mm front sway bar and a 25mm rear sway bar, AMAZING even more and then a strut bar. That did a little bit. But for sure go with sway bars and sturts and shocks. Also maybe look into a polyurethane bushing kit. These are all ideas. put together you've got a great handling machine.
To answer your question quick and easy, kyb agx all around, and some sway bars. for sure! Good luck
Old Nov 5, 2007 | 08:50 PM
You could always bring the suspension on your V6 up to Z28 specs, and get a good handling car on the cheap. Tires are what really make the difference. The best suspension will be of little value with non performing tires.
Old Nov 5, 2007 | 10:00 PM
good point pete. They all work together, tires, sway bars and sturts and schocks and you'll be one ****ing happy camper!
Old Nov 13, 2007 | 02:25 AM
CRanMaro99's Avatar
April 2008 ROTM
Koni shocks is the biggest upgrades you can do to your Fbody. The stock shocks are outright terrible. Then you can look into rod ended LCAs and PHBs for the rear (it needs it) and sway bar upgrades as well... Springs depend if you want to lower or not (if you do lower then you WILL need a new PHB (adjustable) to center the rear end and new LCAs and relocation bracket to help with the wheel hop you will get doing so)
Sudduth49
General Racing/Tech
Nov 6, 2013 08:25 AM
tads71camaro
May 19, 2013 04:29 PM
bmcclz28
LS Series Tech
Jul 4, 2010 01:51 PM
vagabond
Sep 17, 2009 02:36 PM
wr3ck3dm1nd
Aug 11, 2009 07:36 AM
