MKCoconuts Z28 Project
#73
Thank you. It's still getting there and I won't stop till it's what I want...which means I'll probably never stop doing something to it! Haha. I wish I could do a full resto on it. Someday. Someday.
#76
Here's photo's of the whole car with the painted rims. Sorry for the dirtyness. Haven't had time to clean it.
And my new gauges. Haven't gotten them hooked up yet. Still trying to find a good spot in the firewall to run the wires through. For now though, they're mounted, which is fine for me.
#77
theres a good spot under the ecu, be right back. ok, back, look here http://shbox.com/fw/Firewall_wire_feed.html
#78
That'll actually work perfect. Completely forgot about that spot. I all ready have my amp wire running through there so I know it's not too hard to get too. Thanks Craby. Not sure if I'll have enough line for the oil pressure sensor..so might have to pick more of that up.
#80
That's the plan. Just hoping the kit came with all the right fittings. I was hoping to find a spot or drill one in the center of the firewall or on trans tunnel to run the oil line up through since there's not much there. Not too big on having hot oil running into the cabin, which is why I'm gonna run the oil line through 1/4 in. hose as a safety precaution.
