Chaotic's Z28 Progress Thread
Old May 13, 2018 | 10:49 PM
  #71
Chaotic94's Avatar
September 2011 ROTM
Thanks for the input guys! I think I’m going to drop my block off at the machine shop tomorrow and see what they say. I’ll buy a new crank kit and pistons and slap her together. That’s the plan anyway. I’ll keep everyone updated as I get more news. Thanks again!
Old May 14, 2018 | 05:16 AM
  #72
Lakerman62's Avatar
Best wishes for a speedy recovery!
Old May 20, 2018 | 07:22 PM
  #73
Chaotic94's Avatar
September 2011 ROTM
Well the block is good to go. Picking it up from the machine shop on Tuesday. Ordered replacement pistons, a new crank kit with king bearings from Oreillys, new timing set, ARP head bolts, Melling high pressure oil pump, custom grind 227/235...587/600 cam, Lunati double springs, LS7 lifters, and Lunati 1.6 roller rockers. Waiting to get the engine back together to measure for pushrods. I’ll keep you guys updated. Waiting for everything in the mail.
Old May 20, 2018 | 08:46 PM
  #74
Y2K's Avatar
Y2K
Should be sweet when she's up and running again.
Old May 21, 2018 | 12:58 AM
  #75
get the high pressure oil pump. high pressure, not high volume. pretty sure stock is. its what i used on a new block and it has had 60lbs from day one, after 50k miles it drops to 45 at idle when at operating temp but when working its still at 60.
Old May 21, 2018 | 01:01 AM
  #76
lol, nevermind, i see your already on it.
Old May 21, 2018 | 01:03 AM
  #77
im thinking 7.1 on the pushrods if memory serves me. you have a solid lifter to use? i have one for measuring around here somewhere.
Old May 21, 2018 | 07:45 AM
  #78
Chaotic94's Avatar
September 2011 ROTM
No but I’ll install a lighter spring on the valves that I test so it doesn’t sink the plunger on the ls7 lifter while testing for length.
Old May 21, 2018 | 12:50 PM
  #79
Chaotic94's Avatar
September 2011 ROTM
Got some goodies in the mail today
Timing set, head gaskets, oil pan gasket, oil pump, and oil pump drive shaft.
Old May 21, 2018 | 02:57 PM
  #80
Chaotic94's Avatar
September 2011 ROTM
More goodies from a different carrier lol
Pickup tube, low oil sensor, comp pushrod length checker, valve stem seals
