Chaotic's Progress Thread
Old Apr 14, 2013 | 11:31 PM
  #1031
Chaotic94's Avatar
September 2011 ROTM
Well I fixed my oil leak. It was the oil pump drive seal. Also pulled the upper and lower intake and replaced those gaskets. The top end looks relatively clean for 230xxx. Not too shabby if I do say so myself.
Also replaced my upper a-arm bushings, tie rod ends, and bled the hydraulic clutch.
I'll be replacing the clutch pressure plate, disk, throw out bearing, pilot bushing, and shimming the flywheel on Tuesday!
Old Apr 15, 2013 | 12:03 PM
  #1032
Black95M6's Avatar
Loving the progress buddy, I have all the Founders rear suspension pieces and love them. I heard rumors they are making a Torque Arm setup also.... hope its true.
Old Apr 15, 2013 | 01:25 PM
  #1033
Socom's Avatar
November 2010 ROTM
October 2011 ROTM
Told you it was the oil pump drive
Old Apr 15, 2013 | 10:22 PM
  #1034
vanquishfist's Avatar
Old Apr 15, 2013 | 10:25 PM
  #1035
Chaotic94's Avatar
September 2011 ROTM
Yeah it was lol
Old Apr 21, 2013 | 10:25 PM
  #1036
Chaotic94's Avatar
September 2011 ROTM
Turns out I didn't fix my oil leak... I still can't figure out where it's coming from.. Oh well. Here's a mileage update tho.
Old May 9, 2013 | 12:31 AM
  #1037
Chaotic94's Avatar
September 2011 ROTM
Old May 9, 2013 | 12:41 AM
  #1038
slick's camaro's Avatar
Did you find your leak? Check the rear while you replaced the clutch?
Old May 9, 2013 | 01:13 AM
  #1039
Chaotic94's Avatar
September 2011 ROTM
Haven't found the leak yet. I checked the rear main. It was good.
Old May 9, 2013 | 05:05 AM
  #1040
have a look around the rear of the intake and the oil pressure switch
