94 LT1 Z28 swap
Old Apr 11, 2017 | 06:27 AM
Miketheman99's Avatar
Default 94 LT1 Z28 swap
I have a 1994 Z28 LT1 camaro and want to know all the cars that my Current engine will fit into without spend a whole lot of money.
Old Apr 11, 2017 | 09:34 AM
A 1994 Buick Roadmaster, Caprice classic and a Corvette. Are the only RWD cars GM. 1994 is the first year for OBD Computer changed a little in 95 for to use it in a 95 will take some research.
Old Apr 11, 2017 | 08:22 PM
if you want to change the intake and put a carburetor and distributor on it then that opens it up for more.
Old Apr 12, 2017 | 07:01 AM
That going to require a machine shop and some custom made parts to deal with the Opti to HEI conversion?
Old Apr 12, 2017 | 02:32 PM
not really, just leave the opti there. summit has a carb intake for the lt1 that has the hole for the dizzy.
Old Apr 12, 2017 | 06:34 PM
My bad I was thinking of it backwards. Using the LT1 intake on a small block. To bad you get rid of the opti.
94-z28
Feb 4, 2010 02:35 PM
fatherdaughterproject
Dec 11, 2009 10:39 PM
zdav28
Oct 31, 2009 05:36 PM
flywheel_454
70-81 V8 Tech
Feb 19, 2009 09:54 PM
