93 Camaro lt1 Build, Craby's
Old Dec 21, 2009 | 10:29 PM
ordered the tranny today. my xmas present. level 3 raptor with the raptor drive package and the power gear upgrade (2.84 1st gear 1.56 2nd gear). going with the power raptor lockup converter. set back the headers and exhaust purchase for a time. still have a install goal of may. pictures when the tranny arrives.
Old Dec 25, 2009 | 11:43 AM
CNCman's Avatar
Do you have a 93' Z28 and why use the 96' intake ?
I'm just learning.
Old Dec 25, 2009 | 12:03 PM
yes i have a 93, intake has a little more material for lloyd to work when he ported it and the fuel delivery is better.
Old Dec 25, 2009 | 02:53 PM
95slvrZ28's Avatar
What are the ratios on the non power gear units?
Old Dec 25, 2009 | 03:42 PM
1st is 3.06 and 2nd is 1.63. 1st to 2nd ratio drop is 1.28 with the gear and 1.43 stock.
Old Dec 25, 2009 | 08:33 PM
95slvrZ28's Avatar
Alright, so they're regular 4L60E ratios...hmm, interesting. Thanks for the info Craby.
Old Dec 25, 2009 | 09:23 PM
ya from the way i understand it the 700r4 and 4l60 are the same gears. the gear change brings it closer the the 2004r ratios. the 2nd gear shift is supposed to be very smooth and picks up 2 to 3 tens in the 1/4. i was worried about the lower ratio for 1st but with the 370 gears the change should not effect launch at all.
Old Dec 26, 2009 | 01:53 AM
blazelt1's Avatar
craby, how much didlloyd charge to do the heads seeing i cant use my trick flos i might have him do my factory ones. just looking to find out a range on the price?
Old Dec 26, 2009 | 06:12 AM
check it out
http://www.elliottsportworks.com/lt1.html
cost me 1800 bucks plus shipping. got the heads and intake done and got to pick the cam i wanted,. cost depends on what u have done.
Old Dec 26, 2009 | 02:27 PM
  #20
95slvrZ28's Avatar
Yeah, that sounds about right. 1-2 is a pretty hard shift with the stock ratios (and you are correct, the 700r4 is the same as the 4L60, so they have the same ratios. GM actually just renamed the 700R4 in 1993. In case you're curious 4 = 4 forward gears, L = Longitudinally mounted (RWD), 60 = strength rating. Then post 1993 they added the E = Electronically controlled)
With those ratios you could probably consider going for 4.11 gears. I'm not sure what your 3-4 look like, but it's a thought. It's just a little odd to see them decrease the ratio for the "power" option. It makes me laugh a little: 1st gear on my Subaru STi 5-speed is 3.454, 2nd is 2.062...lol
