window issues
Old May 16, 2014 | 11:09 AM
jeffchairs's Avatar
Default window issues
Windows not working no power at the fuse block for window fuse and circuit breaker?any help would be apreated trying to get this car sorted out
Old May 16, 2014 | 12:09 PM
so no power to the brown wire coming out of the fuse box or into the window switch? better take the fuse box out and see if theres something damaged or not connecting right on the backside
http://shbox.com/1/pwr_window_schematic.jpg
Old May 16, 2014 | 04:35 PM
jeffchairs's Avatar
I will try thanks
Old May 16, 2014 | 07:05 PM
carmel73's Avatar
you may want to replace the fuses if none of the power windows work.
Old May 16, 2014 | 09:50 PM
GaryDoug's Avatar
Check to see if the radio also doesn't have power. If so, the problem is with the BCM (body control module). It can be fairly easily repaired.
Old May 16, 2014 | 10:13 PM
jeffchairs's Avatar
The guy removed the radio. But I will check to see if there is power at the plug.it stopped working the day after he pulled the radio out .i wonder if he accidently unplugged something.
Old May 16, 2014 | 10:20 PM
GaryDoug's Avatar
You can measure the voltage at the radio fuse. There are two radio fuses, so measure both. Ignition needs to be on.
Old May 17, 2014 | 08:02 AM
Old May 22, 2014 | 11:25 AM
carmel73's Avatar
I think checking voltage is a good idea too as as GaryDoug pointed.
cornmuffin
Jul 24, 2014 10:22 AM
eric forman
Jul 12, 2013 08:00 AM
Slick6
Nov 1, 2011 10:54 PM
camaro97x1
May 2, 2008 02:01 AM
98sleeper
Apr 20, 2008 07:36 PM
