window issues
Windows not working no power at the fuse block for window fuse and circuit breaker?any help would be apreated trying to get this car sorted out
so no power to the brown wire coming out of the fuse box or into the window switch? better take the fuse box out and see if theres something damaged or not connecting right on the backside
http://shbox.com/1/pwr_window_schematic.jpg |
I will try thanks
you may want to replace the fuses if none of the power windows work.
Check to see if the radio also doesn't have power. If so, the problem is with the BCM (body control module). It can be fairly easily repaired.
The guy removed the radio. But I will check to see if there is power at the plug.it stopped working the day after he pulled the radio out .i wonder if he accidently unplugged something.
You can measure the voltage at the radio fuse. There are two radio fuses, so measure both. Ignition needs to be on.
I think checking voltage is a good idea too as as GaryDoug pointed.
