Window Issues
Old Jul 7, 2013 | 04:46 PM
eric forman's Avatar
Default Window Issues
I recently put a new motor in my drivers window of my 94 (about a month and a half ago). Today when I was getting out of my car I rolled the windows up and when I released the switch the drivers side window rolled all the way down. I was able to roll it up and shut the car off so it wouldnt move anymore. When I got back in it was still doing the same thing. So I disconnected the battery and reconnected it with no new results. I drove home and started messing with it on the way back. It started getting non responsive, but would go up after a little while and get stuck at the top. Then randomly it would roll back down. When I got back home I found out that I can completely control the window when the car was off, but power was still running to accesories. Does anyone have any idea what could be the problem?
Old Jul 8, 2013 | 01:14 AM
i would look at the switch and the express down module.there is some info on windows in the general section in a sticky. be right back. here ya go https://camaroforums.com/forum/lt1-l...25/#post639865 also look in the manual section.
Old Jul 8, 2013 | 02:48 PM
woh that took a while here it is again https://camaroforums.com/forum/lt1-l...25/#post639865
Old Jul 10, 2013 | 08:39 AM
Thank you craby, you are awesome!
Here's an update. I changed out the switch and it still doesn't work. I was messing around with some of the window controls and made my way to the side mirror adjuster. I turned it to the right window and got the driver window to roll all the way up and it stopped. I haven't touched it since because I don't want to have my window wide open. The passengers side is starting to stick for a second now as well.
Old Jul 10, 2013 | 08:46 AM
woh,,,, mirror should not have anything to do with the window... strange.
Old Jul 10, 2013 | 09:02 AM
Yeah I am pretty confused about it
Old Jul 10, 2013 | 09:37 AM
Grab and wiggle the rubber boot that's connected between the front of the door and hinge pillar while working the switch, and see what happens. The wires are run through there, and over time from bending back and forth, a wire can break. It's possible that just you moving the door in general could have put the wires in a momentary sweet spot.
Old Jul 10, 2013 | 05:02 PM
libertyforall1776's Avatar
Also check out these kits:
AutoTrix :: 93-02 Camaro
Old Jul 12, 2013 | 08:00 AM
Alright, ill mess around with it over the weekend and get back to you guys.
cornmuffin
Jul 24, 2014 10:22 AM
jeffchairs
May 22, 2014 11:25 AM
Slick6
Nov 1, 2011 10:54 PM
camaro97x1
May 2, 2008 02:01 AM
98sleeper
Apr 20, 2008 07:36 PM
