window issue
Old May 9, 2014 | 06:28 PM
FBodyjunkie's Avatar
Default window issue
Got a 94 Z28 that sat all winter. Went to start it, and the drivers door window will not move. It's up, so no issue there, however, I can't get it down. What I don't understand, is that it worked fine when I parked it for the winter. It's stored outside in New jersey and it was a long cold winter. But I can't imagine that had anything to do w it since that window motor was replaced in 2010 and has seen minimal use since then, having only put 17k miles on the car in four years. I also just replaced the window switch for good measure. The other window works fine, so I know the fuse is good. I checked it with the defogger fuse which works also, and still nothing. When I do press the window switch, I can hear the relay under the dash clicking. Could the regulator in the door go bad from sitting? I'm going to check for a broken wire between the switch and the motor. I'll check the voltage for low voltage . Is their anything I'm missing?
Old May 10, 2014 | 01:48 PM
Your model year car had issues with the window switch breaking. Way back when I purchased a new 94, the driver side window switch was replaced twice under warranty.
Old May 11, 2014 | 07:21 AM
Yeah, that was the easy part. I'm thinking the motor is seized
pcarollo
May 6, 2012 10:33 PM
DarlingReject
Jan 11, 2011 12:30 PM
dazed&confused
Aug 31, 2010 09:37 PM
montecarlogrrl
Jun 12, 2010 04:50 PM
67Dork
Mar 22, 2010 11:03 PM
