Rear Window Tint- Dot Matrix Appearance
Old Oct 17, 2009 | 10:46 AM
LHill00Z28's Avatar
Default Rear Window Tint- Dot Matrix Appearance
So I had my windows tinted a couple of months ago on my 2000 Z. They look great except for the upper portion of the rear window where the dot matrix is below the solid black area. The tint cured just fine everywhere but the upper dot area looks crappy up close. Has anyone else had this issue??
The car looks excellent inside & out minus this small flaw. I seriously have to do something about it & think that a complete re-tint might yield the same result. I honestly have considered removing the tint from the dot matrix top black border down to the top defrost grid line. Plan to trim out with a sharp razor using this as an outline.
What should I do?? It is driving me crazy as I want a clean look.
Thanks,
Old Oct 17, 2009 | 12:25 PM
GMDCAMARO's Avatar
Picture? I had mine tinted without any sort of issues.
Old Oct 26, 2009 | 01:24 AM
RFxCamaro's Avatar
same thing happened to mine but mine came out with a nice fading look you can kinda see it on my sig
Old Nov 10, 2009 | 11:42 AM
XDC Window Tinting's Avatar
Default Dot Matrix Solution
The best way that I have found is cutting the film to the defrost line, then using that piece as a template, cut black vinyl, stick it on the inside, the vinyl will get between the dots, giving you a flawless look!
Old Nov 14, 2009 | 05:07 PM
LHill00Z28's Avatar
XDC.. Thank you for the great idea! Do you recommend a particular vinyl??
TheArtfulLodger
Dec 21, 2012 09:56 PM
carterbrad94
Mar 10, 2011 03:16 PM
luciora
Jul 12, 2010 06:43 PM
adam3.8
Mar 21, 2010 04:18 PM
bill12690
Dec 15, 2009 02:57 PM
