Need To Remove Dash Trim/New Stereo Install??
Old Jul 24, 2011 | 11:30 AM
xlowes's Avatar
Default Need To Remove Dash Trim/New Stereo Install??
Need to remove dash trim on my 98 to install new stereo. Is there a way to take off just the center trim that goes around the factory unit/AC Vents.
Thanks, Nick
Old Mar 15, 2012 | 03:58 PM
Davila2000maroRS's Avatar
you should be able to pull off the trim around the stereo that goes from your two vents in the middle all the way down to your ac/heat controls.
It should just be able to pull of and your two vents will come out. When you pull it off you also need to disconnect the wires to your foglights and I believe your second gear shift if yours is the same as mine.
Old Apr 27, 2012 | 07:29 PM
androzer's Avatar
not fog light
the rear heaters of the rear hatch window!
xlowes
Aug 18, 2011 07:58 AM
Dudeson
Jul 27, 2011 11:12 PM
Uncle Luke
Oct 15, 2009 12:33 AM
Latinoeheat
Feb 14, 2009 05:59 PM
84PRJCT_CR
May 3, 2008 10:15 AM
