Changing Door Panels?
Old Apr 6, 2013 | 11:39 AM
xdreamweaverxad's Avatar
Post Changing Door Panels?
has anyone upgraded their interior door panel? i really like the look of Trans Am interior door panels. the speaker pods alone are worth a try. question is which year or years are a direct fit or match? 93 thru 97? or will a newer model work as well like 2002 interior panel on to my 1997 ss camaro?
Old Apr 13, 2013 | 06:15 AM
FBodyjunkie's Avatar
The mounting positions are different. An easy way to know that is because on all 4th gen Firebirds, the door panels crack from a faulty mounting design flaw in location. Not so on a camaro. You will have to modify the door panel and door to make it work. There is a cure for the firebird flaw, by relocating the mounting brackets. Look it up on you tube. Good luck. Hope this helps.
Jim-Bob
Dec 31, 2012 05:06 AM
GoofieJ21
Jan 13, 2008 09:45 AM
350rs
Jan 8, 2008 10:43 PM
L0tuS
Dec 7, 2005 12:29 PM
