Bulb in doors power windows switches?
Old Jan 18, 2017 | 05:10 PM
aaberg's Avatar
Default Bulb in doors power windows switches?
Is there any bulb in doors power switches and if so, how do I replace them, seems to be tricky to get inside from back.
Old Jan 19, 2017 | 08:42 AM
peterpar's Avatar
The only light in the doors that I know of are behind the door release handle panel and it should also illuminate the power windows switches. Not sure if you can access it by removing just the release panel or if you have to remove the complete door panel.
I've attached a pdf from the 1996 service manual that should give the approximate location of the light and how to get access to it. Hope this helps.
File Type: pdf
mybbz28
Nov 2, 2009 01:58 PM
jfdye
May 8, 2009 03:51 PM
badlandsusa
Mar 11, 2009 11:53 AM
A320ZDriver
Jul 21, 2007 06:46 AM
