1998 to 1996 interior full swap.
Old Dec 6, 2017 | 08:53 AM
el-chupakabra's Avatar
Arrow 1998 to 1996 interior full swap.
Hey There folks!
Camaro newbie from Estonia here.
Bought a z28 recently which is in good technical shape (except few minor leaks) but have some problems with an interior:
- seats are torn
- upper dash panel is cracked
- ceiling is bad
- armrest opens, but when You open it - it stays in your hands
- stereo works badly in matter of audio quality, also front speakers sometimes go silent.
- someone tried to hold power window switches in door panels using self-tapping screws, that looks nasty
- driver's seat belt doesn't buckle up most of the times
- the car used to have a remote control for a door locks but all remotes lost, central lock buttons also missing
- previous owners were smokers so interior also smells badly.
- Only one key so If i lost it - I'll get problems
Considering all these problems I decided to buy a donor car and swap an interior to my z28 because trying to fix it and buying missing parts from e-bay will be pretty much the same as buying a donor car
Because I'm from Estonia, there are not many options to buy a camaro as a donor, Most of camaros for sale are restyled models, starting from 1998 model year which I see differs a bit from my 1996 z28 so before taking any further actions I'd like to ask a few questions to You guys.
I've been searching this forum for similar topics but I see that most of guys here just swapped seats and some interior panels instead of full interior swap. By full swap I mean swapping everything from a donor to my z28: all wirings, electronic modules, instrument panel etc.
I understand that swapping seats, door panels and etc is quite a bolt-on procedure but what about electronics, instrument panel, heater and so on?
Will BCM from 1998+ vehicle fit my 1996? Should I reprogram it?
What about remote controls? How central locking system is organised in camaros and are there any differences between 96 and 98 camaros?
Instrument panel. I think that I will have to change wirings so new inst. panel could work. Are there any schematics online?
Waiting for any comments, suggestions and advises from You guys.
Thank You.
Old Dec 15, 2017 | 07:26 PM
Thefoodman52's Avatar
I think you're good swapping out the door panels, console, seats, carpet, etc.
The dash and gauge cluster might be a problem though. I know the 1993-1997 cars were all OBD 1, and the 1998-2002 cars are OBD 2. Not sure you'll be able to use the gauge cluster from it.
Old Dec 16, 2017 | 04:11 AM
Thanks, but according to shbox.com website OBDII should be installed on 1996-97 LT1 F-body but I'm definitely gonna check that before taking any actions. I also saw a lot of pre-restyled 4 gens with restyled dash installed. It might be a problem to install it but that is why created this topic: to ask guys here who might done this about possible problems which can occur during the swap. About gauge cluster. I saw a thread somwere here that I can actually leava my old cluster and it will fit restyled dash and I'm thinkging of leaving my gauges now.
Old Dec 18, 2017 | 06:03 PM
hooknladder's Avatar
The 97's had the 98-02 dash in them. Not sure about the rest of the interior. Mine is a true 30th Anniversary Z28. Hugger and Arctic White.
NorthMountain
May 27, 2017 11:44 AM
Chaotic94
Aug 17, 2016 04:46 PM
Badrs2810
Aug 12, 2010 09:49 PM
slovik89
82-92 V6 Tech
May 17, 2007 04:57 PM
soulonfire11
Jan 14, 2007 02:13 PM
