1993-1996 LED Interior Swap ***How to***
Old Mar 6, 2011 | 06:42 PM
  #51
DarlingReject's Avatar
Prettiest Sixer Around
September 2010 ROTM
I wouldn't mess with the odometer. It looks pink when you take pics of it. But it's still red. It's too risky of screwing it up because you have to tear it apart.
Old Mar 6, 2011 | 08:11 PM
  #52
Mizz88's Avatar
Well ive got all the lights swapped out except for the lighting control one, could someone let me know which type of light i need, bearing i mind i have a 97, and what i need to know to get it too work, soldering, etc? thanks
Old Mar 6, 2011 | 08:21 PM
  #53
September 2010 ROTM
Old Mar 15, 2011 | 12:04 AM
  #54
claude1991's Avatar
Thanks man, looks amazing! I definitely see this going into my car in the future!
Old Mar 15, 2011 | 12:23 AM
  #55
Sniper's Avatar
Can I also do this to remove that peski Security light? It stays on even though my car works fine. Its been on for over 2 years and it has bugged me every day.
Old Mar 15, 2011 | 10:09 PM
  #56
Chaotic94's Avatar
September 2011 ROTM
Yup you can remove the security light. It's easy.
Old Mar 15, 2011 | 11:39 PM
  #57
Sniper's Avatar
thanks, I might have to use your sticky after all, even though I'm not changing the leds.
Old Mar 17, 2011 | 01:15 AM
  #58
Sniper's Avatar
Hey man I took the security light out, took me about 2 hours only cuz I had a little trouble getting those screws under the dash out, was trying to be super careful not to break it. I didn't have 7mm wrench so I used some regular pliers to loosen them just a tad bit, then used the 7mm socket and turned it with my hand. Thanks for the steps.
Heres that annoying "Security" Light
Heres everything back to normal. Yay no security light. I took it for a test drive and everything seemed normal. Thanks again for the steps.
And last but not least, the close up. Yes my car is on.
Old Mar 19, 2011 | 04:37 PM
  #59
Chaotic94's Avatar
September 2011 ROTM
Looks great man. Gad I was able to help you out. And yeah those screws under the dash pad are the worst part of the whole process. Everything else is easy
Old Apr 8, 2011 | 12:08 AM
  #60
milkshakeman55's Avatar
Is it basically the same process for the 98-02 camaro's? Was thinking about changing to LED's.
