1993-1996 LED Interior Swap ***How to***
#122
Well, finally got around to doing some pictures at night to get the full effect of the lights. Keep in mind, these pictures were taken with my DroidX. While the quality is usually very good (See my day photos in the "Post Pics of Your 4th Gen" thread), the quality at night drops significantly. Without further ado, here's my results:
#124
I have a question, but first wanted to say, thanks so much for this guide. I did a full LED swap so that I have the blue LED's everywhere. The only exception I have is the Fog light switch, and the window heater switch. These both still have the gunky greenish lights in them. Does anyone know what size bulbs, or what I need to do to switch these out?
#125
mine in red, I did mine back in 09 still lookin good.
#127
I did all 5mm leds in the cluster gauge back light by just soldering the lead to the board and left warning lights the standard bulb.
Mirror and rear dome light I got 6 leds that are 5mm in each. Made on a popsicle stick and works great.
Ac/heat controls, door lights and gear shifter. Are 5mm leds. Headlight switch 3mm led
Stock bose cd stereo replaced all bulbs with 3mm leds.
All cost about 10 dollars and time for some resistors and leds. Made it all myself and always can go back to stock and never looks touched.
#128
For the fog light and defrost switch? How about the sgs and top up/down switch. I would really like to see how you got a 194 in there, when no one else has. Just like you mention that red can't be used on a camaro cluster, I've seen pretty much every color, it's the birds that can't use any other color without switching to a camaro cluster or aftermarket over lay
#130
