WS6 hood vs double vision hood
Old 04-05-2011, 11:29 PM
Failed Devices's Avatar
The way mine mount, there are some tabs that stick out inside the nostrils that the mesh lays on top of, and then gets screwed into. There are normal screws, and the ones you listed are for a Trans Am so I would think they are the same as what I have. You would need to fabricate some sort of tabs for it to mount to I think. You are probably better off doing what Maudy suggested
Old 04-05-2011, 11:55 PM
timmyz28's Avatar
I can give that a try first. If it doesn't work, then I will probably buy the scoops and make them fit somehow.
Old 04-06-2011, 01:47 AM
RFxCamaro's Avatar
I would try to use some epoxy
midwestdave33
05-25-2012 05:32 PM
Failed Devices
06-30-2009 05:21 PM
2lucke4u
05-14-2007 08:06 PM
ridinbikes247
01-10-2007 07:00 PM
ScottD
10-27-2006 06:37 PM
Quick Reply: WS6 hood vs double vision hood
