will lt4 heads fit
Old Apr 27, 2009 | 01:41 PM
93redz28's Avatar
Default will lt4 heads fit
will lt4 heads fit an lt1 and if so will the lt4 hot cam packege work with it and still be abel to use my headers and cai with it and all be good????
what kind of gears should i get???? STREET/STRIP
chip??
Old Apr 27, 2009 | 04:36 PM
Saint_Ali's Avatar
yes lt4 heads will fit,but you will need an lt4 intake manifold.The hot cam package will work with it also.You still will be able to use your headers and cai.Do you know what current gears are in your camaro ? you will need to get a chip burned for the mods you have done for best results.
Old Apr 27, 2009 | 09:34 PM
95slvrZ28's Avatar
You can get significantly better performance/dollar if you go for a good aftermarket porting/polishing of your stock heads and a cam to match. There are multiple threads in the LT1 section about this exact issue, check them out.
fbodyhemi69
LS Series Tech
Dec 7, 2009 05:16 PM
SixShooterCamaro
Oct 30, 2009 08:58 PM
Red Demon
Oct 25, 2007 02:29 PM
1983_JAL
Mar 23, 2007 11:57 PM
