Whos Lowered Without Panhard? LS1 or LT1
Old Apr 23, 2010 | 05:05 PM
traumadog's Avatar
Originally Posted by auto
i see...what exactly does it control?
It locates the axle on a left-right sense, but allows the axle to move up-and-down.
BMR's install instructions...
http://www.bmrfabrication.com/instructions/phr003.htm
Old Apr 23, 2010 | 06:45 PM
DarkKnight's Avatar
GTO Killer
LimeKnight
Ok so i can get by for a few weeks with my drop and no adjustable, thanks guys
Old Apr 24, 2010 | 08:01 AM
Not only does the bar locate the axle left to right, it keeps the rearend from tearing out altogether. All cars that have a control arm type rear suspension have to have some type of locater bar, whether it's a panhard bar or camber rods, etc. Rear control arms have no lateral (side to side) stability, which is why the bars are needed.
Old Apr 24, 2010 | 09:27 AM
auto's Avatar
if this is bent or bushings bad the ends, this would cause the car to fishtail alot more than usual?
Old Apr 24, 2010 | 09:56 AM
A bent bar wouldn't cause that unless it's flexing like a spring. But sloppy bushings can cause side to side body sway as the bar mounts will have some give. Fishtailing from the tires breaking free from the pavement is less likely to be a symptom.
And this may sound like an archaic way, but as a quick fix after lowering the car, you could "tweak" the stock panhard bar to put a slight radius to it, which will shorten it. You obviously have to have the bar off, center the rearend with the body, and test fit as you go. Better yet, if you have a welder, you could cut the bar apart, shorten it, and re-weld it reinforcing it with a gusset.
Old Apr 24, 2010 | 11:24 AM
auto's Avatar
hmm so what would cause it to fish tail more than usual? like on turns losing control?
Old Apr 24, 2010 | 12:56 PM
evilkal's Avatar
I don't see why a V6 owner couldn't answer this. Panhard rod has NOTHING to do with weight distribution. It centers the rear to the axle. A V6 guy can answer your questions just as good as a V8 guy (02StanGT being a great example) and V6/V8 isn't gonna be a difference 99% of the time.
gagger84
Jul 23, 2012 06:13 AM
A2TURBO
Jan 11, 2012 01:56 PM
SHOoffSS
LS Series Tech
Oct 6, 2009 03:39 AM
CRanMaro99
Sep 20, 2007 02:26 PM
