Whats wrong with these subs.
Alright I am deciding between these three subs I will be buying two of what sub I buy because my box Is 2 tens. Between the two kicker cvr models Im not sure which one Is better they have the same wattage specs but one Is dual voice coil Idk If those are better then the single or If they break easier etc. Um If you have any subs that you would reccomend for the seventy or under price range then you can also If you can find me a amp for a nice price that would also be nice. I still need to find an amp and Im not sure If you are supposed to match the amp with the rms value of the subs or go a little bit higher. Also If anyone knows the difference between mono amps or the different classes that would be helpfull thanks.
Amazon.com: Kicker 10C104 Comp 10-Inch Subwoofer 4 DVC (Black): Electronics
Amazon.com: Kicker CompVR 07CVR104 10" subwoofer with dual 4-ohm voice coils: Electronics
Amazon.com: Kicker CompVR 07CVR104 10-Inch 4-Ohm DVC Subwoofer: Electronics .
Check out this site: Learn about Category Car Audio & Video There is a lot of great info there that will answer your questions.
