whats wrong?
Old Nov 18, 2008 | 05:36 PM
Kyle95.3.4L's Avatar
Default whats wrong?
I was getting a squeel outta my a.c. comp. so i replaced it with a brand new one. But 2 days after that the squeel returned so i replaced the water pump, and belt. didnt fix it so i replaced the tensioner, still doin it. seems almost like it is still comin from the water pump but not really positive. any input?
Old Nov 19, 2008 | 02:23 AM
02StanGT's Avatar
Default RE: whats wrong?
Idler pulley?
Old Nov 20, 2008 | 02:08 PM
libertyforall1776's Avatar
Could be the Alternator, Water Pump, Idler pulley sounds like a bearing is going out on one of them was the tensioner bad? If so and you drove with it bad for a while, it could have caused one of the other problems...
The water pump could be going, is it leaking coolant through the weap hole? Engine running hot? I did the water pump job myself with a reman one on my 95 3.4 the job wasn't too bad, just be sure to rent a pulley puller if you don't have one!
Old Nov 20, 2008 | 09:26 PM
RSSteve's Avatar
ORIGINAL: libertyforall1776
As he stated he already replaced the water pump so thats not it..... Check the condition of the belt its self for any unusual wear. Look very closely in the ribs of the belt for dirt or gravel. Also while the car is running spray the belt down real good with some brake cleaner.
Also take the belt off and spin all the pulleys one at a time to make sure they spin freely and smooth and they aren't loose (side to side) and worn.
94ChevyCamaroV6
Feb 9, 2012 11:28 AM
mikey_11
Nov 28, 2009 04:06 AM
DeadMedic
Jul 24, 2009 10:12 PM
krdono2
May 24, 2009 11:39 AM
christinad
82-92 V8 Tech
Jul 7, 2006 09:54 PM
