Whats the best trans fluid to use?
Old Oct 13, 2012 | 12:46 PM
Camaroboi22's Avatar
Question Whats the best trans fluid to use?
What's the best fluid to use for a 4l60E I just beefed it up with better clutches and servos. And how many arts do I need including the torque converter which is a 3000 stall 10inch?
Old Oct 13, 2012 | 11:11 PM
2Z's's Avatar
Look into Amsoil products. I started using them a couple of years back and Im impressed with the quality of them. I used special 10w40 with Zinc in my 92 ZR-with good results. Also, I use the Amsoil Torque Drive in my Z06. Its an automatic transmission fluid, but its compatable with the T-56 transmission also. My shifts are smoother and it really helped with cold temperature shifting.
Link: https://www.amsoil.com/a/synthetic-t...uid?zo=1924301
Old Oct 13, 2012 | 11:54 PM
MKCoconuts's Avatar
Amzoil, Royal Purple, and Red Line are top of the line products. I have Valvoline Max Life in mine right now, but I don't run it too hard, but it doesn't have an easy life either.
Old Oct 28, 2012 | 03:54 PM
libertyforall1776's Avatar
Any Dexron 6 fluid should be fine. Don't go with a lower number Dexron anymore, they have been superseded, despite your Owner's Manual...
Old Oct 29, 2012 | 07:54 AM
torque_is_good's Avatar
12 quarts plus perhaps a wee bit more for a complete fill including T/C but be sure to follow the proper process and let it warm and check when on flat surface and idling.
Old Oct 29, 2012 | 03:07 PM
Edwardgp's Avatar
I like Amzoil Transmission fluid.
Old Oct 29, 2012 | 05:57 PM
cplthomas's Avatar
HELP ME TOM CRUISE
Yaaarrrrrr
Royal purple. How much tans fluid came out when you drained it... thats how much to put back in - in general.
Old Oct 30, 2012 | 10:45 AM
MKCoconuts's Avatar
A full fill for the trans (including TC) is 10.8 quarts for a stock 4L60E. Just the pan would be 5 quarts.
dogdog130
Jun 6, 2011 04:18 PM
dantheman
LS Series Tech
Jun 29, 2009 08:59 PM
1996fbodyz28
May 14, 2009 11:15 PM
1989_RALLYSPORT
Nov 3, 2008 03:23 AM
Parabola
82-92 V8 Tech
15
Sep 19, 2006 08:14 PM
