What does a failing wheel bearing sound like on a 98 Z28
Old 09-17-2017, 07:54 PM
Ted Larkin's Avatar
Default What does a failing wheel bearing sound like on a 98 Z28
What does a failing rear wheel bearing sound like on a 98 Z28? I've got a rubbing sound from the rear of the vehicle which I can not hear with the convertible top down driving down the road or at speeds above 35 mph. It's mainly at lower speeds I notice the sounds. Was thinking it could be from the rear brakes or the parking brake shoe... The car has 74k on the odometer. Thx..
Old 09-17-2017, 09:04 PM
Lakerman62's Avatar
Sometimes it may be one of the rear calipers sticking.
Old 09-17-2017, 10:08 PM
Wheel bearing will change sound as you add and remove weight to it. So if you weave the car back and forth. The noise should get louder as the car leans then get quiet as it leans weight off the bad bearing.
Old 09-18-2017, 08:28 PM
Y2K's Avatar
Y2K
Y2K is offline
Low mile car like that I'd suspect brake dust or something brake related before bearings.
Old 09-18-2017, 09:01 PM
Ted Larkin's Avatar
I was looking closely through the wheel and see the rear rotors are not equally worn. One has rust pitting and looks like a record player on the outside area where the pads are supposed to make contact. The other side of the car the rotor is completely smooth and has no rust. Looks like some rear brake work may be needed
Old 09-19-2017, 07:28 AM
I have also seen the chrome on the inside of the wheel lift up a little and cause a rubbing sound, but it could be the brakes.
Check out the Power Stop kits at Rock auto. They seem to be the cheapest short of Ebay/china ones.
Old 09-19-2017, 12:29 PM
95 camaro 406's Avatar
with a wheel bearing jack up the car if the wheel moves up or down left or right to much ,thats how you tell it needs one,sounds like a warped rotor or could be a line collapce too
94Z28SHAKER
11-13-2007 05:36 PM
microkid
06-05-2007 08:26 PM
mwilder87
LS Series Tech
03-08-2007 06:05 PM
Saint_Ali
09-25-2006 12:11 AM
Quick Reply: What does a failing wheel bearing sound like on a 98 Z28
