does this sound like it would work?
Old May 31, 2007 | 04:18 PM
microkid's Avatar
March 2011 ROTM
Technical User
Default does this sound like it would work?
i plan on getting some slicks for my car sometime in the future. im looking at getting a short tire, something like 20-22" on a 14" rim. however, that would put a funny angle on the car that would probably hurt the performance going down the track. but i find it quite easy to get the rear springs out of the car (just unbolt the shocks and sway bar links, all are new). would it be alright to put in a 1 1/2" spring spacer on both the top and bottom of the spring? it would probably take me an hour to do at the track, and would be able to undo it before i left.
Old May 31, 2007 | 08:17 PM
1985RS's Avatar
Default RE: does this sound like it would work?
if your worried about traction, just drop the psi in your tires
Old Jun 2, 2007 | 02:50 PM
microkid's Avatar
March 2011 ROTM
Technical User
im more concerned about saving my street tires for the street. the tire is a bit too big for the rim, and i already run it at 20 psi
Old Jun 2, 2007 | 10:04 PM
Danzig's Avatar
Keep the *** end lower, this will give you better weight distribution, thus a better launch off the line. Put on subframe connectors also.
Old Jun 5, 2007 | 08:26 PM
camarohelp's Avatar
Dropping PSI is a great way to prematurely destroy your tires and lower your mileage. Not to mention the increased resistance to movement slows your car down.
But if traction's really worth that much, by all means...
Rebelson
82-92 V6 Tech
Sep 20, 2011 01:13 PM
sledneckZ28
Apr 9, 2008 07:22 PM
nickyt90
Feb 4, 2008 06:08 AM
drygaudet
Jan 26, 2007 03:58 AM
