Weird no start & stalling
Old Aug 18, 2016 | 01:48 PM
Thirdgens88's Avatar
Originally Posted by craby
try and see if its lack of spark or fuel that is causing it to die. best place to start. if its no spark then the opti would be something to look at.
Having no spark & noid light only lights once at start of cranking, it kind of tries to start sometimes but didn't "try" to start with spark tester on at all so I guess intermittent spark.
Old Aug 18, 2016 | 02:10 PM
95 camaro 406's Avatar
could be your opti spark plugs wires with spark it can be so many things ,this is last I guess
Old Aug 18, 2016 | 03:34 PM
noid light should blink when trying to start the engine. it very well could be opti. are you getting power to the pink wire to the coil when the key is on?
Old Aug 18, 2016 | 03:35 PM
Old Aug 20, 2016 | 12:31 PM
Well, in my quest to change the optispark I have nearly given up. There is no possible way for me to remove the harmonic balancer, the sway bar is too far in the way to use any kind of force to try and beat it off and a puller is going to pull the hub as well because there are no threaded holes in the pulley itself just through to the hub.
charlesn110
Jul 7, 2015 10:01 PM
VALHAR
Aug 10, 2013 10:52 AM
Sheriff420
82-92 V6 Tech
21
May 21, 2011 09:24 PM
Ofallah
Jun 12, 2010 11:46 PM
finfan13
Jun 8, 2010 04:35 PM
