P0452 and misfiring
Old Aug 21, 2016 | 11:23 AM
Metalvayne's Avatar
Default P0452 and misfiring
I've mentioned these issues before, but I've still been unable to fix them and I need some more help with my '02 3.8. I have a bluetooth code reader, so I can clear and manage codes and some info. If there's anything you know a scanner can tell you in relation to these problems, I'll tell you.
I know the code P0452 is Evap emissions system low sensor input. I've had the fuel pump with sending unit replaced, and everything checked out then so I believe bad wiring isn't the case here. Also replaced the fuel filter, changed the spark plugs and wires, one ignition coil gas cap. My city doesn't have emissions and this issue hasn't caused any trouble, just an ugly & annoying SES light.
The misfiring always happens around 70+mph. I tested driving without overdrive, and it still happens but at a lower speed. The only codes that it's ever thrown were multiple random and cylinder 3.
Old Aug 21, 2016 | 12:50 PM
copied this, you may have already seen it.
Common Problems That Trigger the P0452 Code
Defective Fuel Tank Sending Unit
Defective or damaged Fuel Tank
Defective Fuel Tank Pressure Sensor, wiring, or computer
Defective Carbon Canister
Defective Canister Vent Valve - in some cases
Metalvayne
Jan 17, 2016 05:00 PM
myk3
Jun 4, 2009 06:19 PM
6v49der
May 7, 2007 06:01 PM
bones3010
Apr 21, 2007 05:53 PM
94z28chick
Jun 22, 2006 11:05 PM
