Water Pump and Opti-Spark
Old Oct 25, 2007 | 10:04 PM
vanmarshall's Avatar
Default Water Pump and Opti-Spark
Started out with an intermitent power steering problem. Thought I had a belt tensioner issue. As I dig deeper, looks like water pump leakingfrom weep hole onto belt, causing belt to slip ocassionally. Finally have water pump off. Do I need to change opti-spark while its staring me right in the face, before I go back on with new water pump?(110,000 miles)And if I do, how do I install properly. GM manual says bring #1 piston to TDC. Hows the best way to do this. Any other info would be appreciated. I really don't want to do this twice! Thanks Van Marshall 1997 Z-28 Camaro
Old Oct 25, 2007 | 10:06 PM
TrammelZ28's Avatar
Default RE: Water Pump and Opti-Spark
if the water pump leaked onto the opti it is prob a good idea to change it. i would just get the gm replacement. i went with the accel its not worth it
Old Oct 25, 2007 | 10:14 PM
8485Chevycowboy's Avatar
ya i would if ur that far, make sure ur not leaking water or oil anywhere else or ur just wasting ur time and money, i would say the same get a gm opti-spark i haven't really heard anything good or better about any other opti-spark.
bd92rs
Sep 26, 2011 11:17 AM
BMCossey97Z28
May 17, 2010 09:31 PM
rwing7486
Aug 24, 2009 06:59 AM
vanmarshall
Oct 29, 2007 09:52 AM
