Water Pump and Opti-Spark
Old Oct 28, 2007 | 11:06 PM
vanmarshall's Avatar
Default Water Pump and Opti-Spark
1997 Z-28 Camaro. Auto trans. Changed out water pump w/new180 degree thermostat,and opti spark. Cranked it up and it runs fine, but can't fill with coolant. Both bleed screws are removed. I have changed the coolant out before, and I am familiar with bleeding the air from the system.I'm thinking I may have not had the water pump coupling shaft lined up, therefore forcing it into the back of the pump. Have I damaged anything besides the pump? What else could be wrong? Thanks, Van Marshall
Old Oct 29, 2007 | 09:52 AM
gotalcoholmanup's Avatar
Default RE: Water Pump and Opti-Spark
when i replaced my water pump i had to let it go through heat cycles to allow the water and coolant to be pulled into the water pump and throught he motor.
bd92rs
Sep 26, 2011 11:17 AM
BMCossey97Z28
May 17, 2010 09:31 PM
rwing7486
Aug 24, 2009 06:59 AM
vanmarshall
Oct 25, 2007 10:14 PM
