water pump
Old Feb 22, 2012 | 04:47 PM
mab6680's Avatar
Default water pump
i found a small leak in my water its coming from the top of the pump right where the inspection plate meets the pump housing and i mean small more like sweating out is there a gasket that goes under the inspection plate or is this a sign the pump is on its way out
Old Feb 22, 2012 | 05:53 PM
Inspection plate? Usually the only things that really go wrong with a water pump are the shaft bearings and shaft seal. Leaks at other places are usually the result of failed gaskets.
Old Feb 22, 2012 | 06:02 PM
mab6680's Avatar
well i guess when i take that plate off tomorrow i can check the bearing
VALHAR
Dec 4, 2010 11:51 PM
cadmanof50s
Sep 22, 2010 08:38 PM
imcdowel
May 8, 2010 10:13 PM
camarorz28
Jan 27, 2008 02:57 AM
