v8 swap
Old May 9, 2007 | 02:25 AM
badhabit's Avatar
Default v8 swap
hi i'm new here um and i was thinking about buying a 1993 1994 camaro v6 hopeing i can get it cheap with the v6 haveing 19000 miles on itand i am souping up a 350 to go in it i searched it on google and could not find anything but basicly i am swaping the 350 and putting it in a v6 camaro can anyone tell me will the tranny bolt up or if i might run into any problems? and has anyone tried this before? thanks justin
Old May 10, 2007 | 08:38 PM
lucky14's Avatar
Default RE: v8 swap
I am doing the same thing.. just picked up my 93 V6 for 200 that runs... but here is what I know so far that you will need
Front cross member
Engine
Transmisson
Engine Harness
ECM
Driveshaft
Rear Axle Assembly
some people will tell you springs... but the listing for V8 and V6 springs are the same
Dual Fan setup for the radiator
engine mounts and trans mounts
thats just what I know is off the top of my head... plus ALOT of wrenching and patientce
Old Jul 12, 2007 | 03:11 PM
genvoodoo's Avatar
Default RE: v8 swap
You can add me to this project direction. I just bought a 94 with the v6. The transplanting motor is the 1975 350 v8 with 350 turbo trans. Fresh back from the machine shop and pushing 400 + horses. I'm going for the sleeper look. Thanks for the info and any additional will be helpful.
Old Jul 12, 2007 | 03:20 PM
Redneck97's Avatar
Default RE: v8 swap
you dont need to swap the trans if im not mistaken the trans will bolt right to the V8. And the driveshaft is fine th only major thing that needs to be chaged is the motor mounts and ECM
bluovlh8er's Avatar
Default RE: v8 swap
its hard and if you dont get the exact motor you will need to replace everything
Old Jul 12, 2007 | 03:35 PM
genvoodoo's Avatar
Default RE: v8 swap
I am planning on parting out the items I don't need. So far this includes: 3.4 v6 (106,000),tranny,possibly the ecm and wire harness. The motor going in is carburated, doubt I'll need alot of the other crap.
Old Jul 12, 2007 | 06:08 PM
JD1969's Avatar
Default RE: v8 swap
ORIGINAL: genvoodoo
Have fun fitting that carb under the cowl/windshield. It can be done but you will need to cut that area out and use a cown induction style hood.
Old Oct 2, 2007 | 10:15 AM
joes94's Avatar
Default RE: v8 swap
Yes, it can be done. I did it in my 94 that had a 6 banger in it. Check out BMR Fabrications web site. They will have everything you need to do the swap. Hookers long tube headers for an LT1 will bolt right up aswell.
3800_seriesII
Aug 14, 2012 07:24 AM
9434V6
Sep 8, 2011 11:51 AM
xXChipXx
Aug 1, 2010 10:39 PM
miclo88
Oct 15, 2009 07:38 PM
85z285.0
Jun 2, 2007 03:19 PM
