upgraded suspesion for horsepower
Old Sep 3, 2011 | 05:14 PM
NorthernCrew454's Avatar
Default upgraded suspesion for horsepower
After completing my 530 hp 383 build, how should i go about changing the suspension to put the power to the ground?
Old Sep 3, 2011 | 05:31 PM
welded sub frame connectors, adjustable torque bar and crossmember relocation, 12 bolt or 9 in rearend, rear lower control arms, good shocks, what trany are you usin?
Old Sep 3, 2011 | 06:54 PM
Performabuilt level 2, Pro Race 4L60E
Old Sep 3, 2011 | 11:41 PM
libertyforall1776's Avatar
How will you be using the car? Street? Autocross? Strip? Road Courses? These matter in your selection of suspension, i.e. a dragstrip optimized car will handle very poorly...
Old Sep 4, 2011 | 12:59 AM
sweet,,,better get the drive shaft loop on the torque bar crossmember. yep look over what strano has on his website and if your gona buy something give a call let him know what you have and what it will be used for, he will come up with some very good options.
Old Sep 4, 2011 | 10:17 AM
street/strip
Old Sep 4, 2011 | 10:33 AM
vanquishfist's Avatar
I agree with Craby, call Strano and they'll tell you what will be best.
Old Sep 5, 2011 | 11:15 AM
Definitely phone Strano, and I would also look into Strano sways -- for the strip a lot of guys remove the front bar, but for the rear get Strano's *adjustable* rear bar -- that way you can firm it up for launches and bring it back to streetable for handling...
Depending on your rear-end either Koni SAs or DAs -- drag shocks like QA1s will be no fun on the street...
XxCaMeLxxToSiSxX
Dec 6, 2010 09:02 PM
nazariol
Jul 22, 2008 02:19 PM
camarokid1
May 21, 2007 12:49 AM
Eric89RS
VS
Sep 28, 2006 03:13 PM
