Universal Catayltic converter for my 98, under passenger side
Old Jun 5, 2013 | 07:46 AM
AmericanMuscle1989's Avatar
Default Universal Catayltic converter for my 98, under passenger side
Hi all,
The catalytic converter under the passenger side is rattling, very, very loudly and so I would like to get it replaced.
Here in England there arn't going to be any replacement parts so I will need a universal replacement.
So I need the measurements of the exhaust like the diameter and length and anything else I might need.
I hope this works out ok, hoping there a CAT with a big enough in and out pipes as the pipe looks big under there.
Thanks guys
Alex
Old Jun 5, 2013 | 10:26 AM
make sure the rattle is not coming from the metal heat shield thats between the cat and the car body. common problem.
Old Jun 5, 2013 | 11:20 AM
cat is for a v8, v6?
Old Jun 5, 2013 | 12:39 PM
libertyforall1776's Avatar
Get a high-flow cat, such as what Magnaflow sells -- you should be able to mail order it...
You might want to take advantage of this situation to do some exhaust upgrades at the same time!
Old Jun 5, 2013 | 01:35 PM
Be ready to fabricate. The pipe leading up to the Cat is not round. Because of the floor it is shaped like a D.
Old Jun 8, 2013 | 03:08 AM
mfmfim's Avatar
I'm taking it's a V8. I would first look at the hangers and make sure they are not discontented.
Old Jun 8, 2013 | 04:04 AM
Hi all,
Thanks for the comments.
Definately the cat itself that is the problem and not any kind of heat shield or brackets. A local garage I took it to is going to replace it on Tuesday so I will keep you posted.
Darn rattling noise is really annoyng me as when I put the roof and windows down at low speeds around town I can hear it in addition to when I come to a stop when I can really hear it!
Thanks
Alex
AmericanMuscle1989
Oct 17, 2013 07:51 PM
KiddCamaro
Nov 26, 2011 04:52 PM
tirocz
82-92 V8 Tech
Mar 25, 2008 05:38 AM
DoubbleQue
Feb 20, 2008 06:47 PM
b4cmoose
Jun 6, 2006 07:31 PM
