Unbalanced Engineering Steering Pin Fix
Old Sep 13, 2022 | 07:32 PM
Wruff's Avatar
Default Unbalanced Engineering Steering Pin Fix
Has anyone tried these ?
https://www.unbalancedengineering.com/GM/Pins/
I have that nasty movement on the wheel. Thought I was used to it but finding the slack will show when I'm really ear'oling and that's not good.
Old Sep 14, 2022 | 07:09 AM
I used them and thought they worked great. I also Bought there Rag joint eliminator. There is no play in my 93's steering.
Old Sep 14, 2022 | 07:07 PM
Wruff's Avatar
Looks fun dissembling the steering column !!
Can't wait......
Old Sep 15, 2022 | 02:51 PM
I assumed you had done it. Is the car high miles? There are 4 bolts that can come loose that can cause the same thing. Do you have any of the tools? I am sure there are videos on how to do it without the right tools but the spring compressor is nice to have. That friken snap ring can really fight you. Maybe you will get lucky. I have had some that came off easy and some that made me want to light the car on fire.
Good Luck.
Old Oct 2, 2022 | 06:41 PM
Wruff's Avatar
Got the rag eliminator installed, boy what a delight !!
Also put the BMR front A arms on. Really good feel.
I bought the lower arms that have an inch drop.
I only wanted 1/2 inch so I shimmed under shock with 1/2 inch spacer.
Think I forgot fundamental geometry, angles of moment etc. Think I only need 1/4 inch spacer to get that 1/2 inch drop.
Hmmmmmm.
Diego Vergara
Feb 11, 2016 07:12 PM
sgreg831
Nov 15, 2012 05:41 AM
vashtx
LS Series Tech
12
Aug 27, 2009 05:07 PM
hascet
Jul 31, 2008 10:08 AM
1979RS
70-81 V8 Tech
Feb 20, 2008 07:45 AM
