Twitching Oil Pressure Needle
Old Apr 26, 2011 | 07:34 AM
AlaJoe's Avatar
I had a similar issue with my V6:
https://camaroforums.com/forum/v6-te...tuation-60401/
I read craby's link above (which is a very good write up) and all I can say is "I am glad i have a v6" In the 3800 V6 it is actually easier to change the sending unit than to change the oil filter. I swapped one in Autozones parking lot in less than 5 minutes.
Old Apr 26, 2011 | 01:51 PM
Catmaigne's Avatar
Originally Posted by craby
so your at the first mark at an idle and the second mark at throttle up. thats 20 to 40 pounds or there about and is quite normal for a higher milage motor.
Define high mileage... My Z28 only has about 80,000 on it. Are the pressure gauge fluctuations normal? Or does it need a tune up?
Also, could it have anything to do with the fact that my car has an EGR valve needs replacing? (has an OBD2 code about restricted gas recirculation)
Old Apr 26, 2011 | 07:00 PM
at 80k thats ok pressure. could be better, could be worse.
Old Apr 27, 2011 | 09:00 PM
z28?SS?'s Avatar
Ya, that thread with the step by step is very helpful! Thanks for posting that. It sounds like I will need to have another vehicle to drive while this one is immobile though, which means I won't be able to do this job until I get my bikes shipped out. I think all-data said its a 2.4 hour job for a shop. I guess I will have to get that re-locater kit, that way if it were to happen again I wouldn't have to do so much work.
southw2
Mar 4, 2011 07:13 PM
96ZLT1
Jan 10, 2011 09:50 AM
JLayer
Sep 17, 2009 12:47 AM
tipdrip215
Jan 10, 2009 09:59 PM
citydragon
82-92 V8 Tech
Jul 18, 2007 12:31 PM
