Turn signals not working on '98 Camaro
Old Dec 28, 2018 | 11:50 AM
mark in IL's Avatar
Default Turn signals not working on '98 Camaro
All the bulbs are functional, flash with hazard switch. I get no indicators or bulbs lit when using turn signal switch. No current at flasher connection, fuse is good and have 12V at both sides. Seems to me switch in column must be bad. Is there anything else to check before I dig into that?
thanks
Old Dec 29, 2018 | 02:40 PM
mark in IL's Avatar
SO I disconnected this connector on the underside of the steering column, thinking it was the one in the turn signal switch wiring. After I disconnected it, the turn signals began working again, and continued to work after plugging it back together. Anyone know what this connector is hooked to? Wipers perhaps?
Old Dec 29, 2018 | 02:41 PM
mark in IL's Avatar
Old Dec 30, 2018 | 03:43 PM
Everett#2390's Avatar
Twilight zone … does everything else work?
Old Dec 31, 2018 | 09:36 AM
pink wire would make me think ignition. musta moved the right wire the right way. must have something goin on in the column wiring.
Old Jan 1, 2019 | 02:17 AM
mark in IL's Avatar
Well, everything in that area seems to work. ABS light is on, so need to look into that at some point.
Post a good Bessie pic.
Old Jan 1, 2019 | 02:20 AM
mark in IL's Avatar
Could be, but I couldn't see any corrosion or wire damage. Car hasn't been driven regularly in 2 years. Seems that gremlins work overtime on parked vehicles.
Old Jan 1, 2019 | 09:29 AM
As requested,
Bessie & Hudson
Old Jan 1, 2019 | 01:14 PM
Y2K's Avatar
Y2K
As requested,
Bessie & Hudson
Had our old girl put down at 14 about 2 1/2 years back, looking for another female Bassett puppy this year probably come springtime.
She had a pretty good run for a Bassett making it to that age.
I bought a 6' X 13' kennel for outside when we're not home and plan on fencing in part of the property (We have 5 1/2 acres) sometime next Summer.
Sure miss that silly dog, Bassetts are such loveable clowns.
Old Jan 1, 2019 | 03:57 PM
Adopt, Adopt, adopt, as rescued dogs give 120% for a forever home.
They appreciate the effort.
