Turn signals not working on '98 Camaro
All the bulbs are functional, flash with hazard switch. I get no indicators or bulbs lit when using turn signal switch. No current at flasher connection, fuse is good and have 12V at both sides. Seems to me switch in column must be bad. Is there anything else to check before I dig into that?
thanks |
SO I disconnected this connector on the underside of the steering column, thinking it was the one in the turn signal switch wiring. After I disconnected it, the turn signals began working again, and continued to work after plugging it back together. Anyone know what this connector is hooked to? Wipers perhaps?
Twilight zone … does everything else work?
pink wire would make me think ignition. musta moved the right wire the right way. must have something goin on in the column wiring.
(Post 729932)
Post a good Bessie pic. |
Originally Posted by craby
(Post 729940)
https://cimg5.ibsrv.net/gimg/camarof...788368143c.jpg
(Post 729969)
As requested,
Bessie & Hudson She had a pretty good run for a Bassett making it to that age. I bought a 6' X 13' kennel for outside when we're not home and plan on fencing in part of the property (We have 5 1/2 acres) sometime next Summer. Sure miss that silly dog, Bassetts are such loveable clowns. |
Adopt, Adopt, adopt, as rescued dogs give 120% for a forever home.
They appreciate the effort. |
