Turn signal help
Old Dec 15, 2019 | 11:12 PM
Grabaho's Avatar
Default Turn signal help
I have a 94 z28 turn signals quit dont work outside or inside wont light up dont make any noise nothing I've checked all fuses all bulbs replaced both flashers signal switch even the stock still nothing can someone please helping dont know what else it could be
Old Dec 16, 2019 | 10:11 AM
Everett#2390's Avatar
Do BRAKE lights work?
Do Emergency flashers work?
All above systems, and Turn Signals, use their own battery power.
Old Dec 16, 2019 | 11:50 AM
check for power at the blinker switch. download factory service manual for your year here, https://www.mediafire.com/?40mfgeoe4ctti you will find wiring diagrams in it also trouble shooting.
Old Dec 16, 2019 | 10:37 PM
peterpar's Avatar
It sounds like the turn signal circuit has no power supply. I would go to IP fuse panel and check for voltage at the #2 fuse with one lead of a test light or meter connected to a body ground and the other to both sides of the fuse holder with the ignition switch in the run position. You should have voltage to both sides. If there is voltage to only one side of the #2 fuse, the fuse is bad. If you have no voltage to either side, that would indicate the contacts in the ignition switch are bad or the orange wire is broken between the switch and the fuse. I've attached the drawings that should help tracing the circuit.
File Type: pdf
Old Dec 25, 2019 | 02:28 AM
Grabaho's Avatar
yes all other lights work i checked the fuses with test light noticed 2 didnt have power so i jumped them to another and signals started working but quit again after 1 day so still no signals
Old Dec 25, 2019 | 02:29 AM
Grabaho's Avatar
Old Dec 25, 2019 | 02:33 AM
Grabaho's Avatar
that sounds like it could b the problem no2 fuse has no power thanks for your help
Old Dec 25, 2019 | 06:36 PM
Grabaho's Avatar
Thank you that sounds like what's happening no power on no2 thanks again
Pro78z28
Aug 3, 2013 12:39 PM
Pro78z28
Jul 24, 2013 03:58 AM
izayuhgawd
Nov 21, 2011 09:24 PM
slidejob26
Sep 12, 2010 10:49 PM
Mad Aaron
Jul 30, 2009 01:39 AM
