Transmission Jumps
yup just replace the mount its really easy to do with just some basic hand tools and a jack
jack up car and support with stands
unbolt the 15mm nut holding the mount to the cross member
then jack up the trans an inch
unbolt the 4 15mm bolts for the cross member
and unbolt the 2 mount bolts 18mm i believe
bolt on the new mount
bolt the cross member back up
let the trans down
bolt down the 15mm nut
and your done shouldnt take more than 30 min
let the trans down
^ Except for the unbolt the crossmember part. I replaced the mount on my old 4th gen twice (first a stock rubber one, then a poly), and didn't need to drop or lower the crossmember at all.
Thanks guys. After I posted the question, a buddy and I crawled under it and that's what we suspect as well. The guy I bought it off of says he put a new transmission mount on it, but I'm thinking that's not the case.
