these dyno numbers dont sound right
Old 01-26-2012, 09:27 PM
that depends on why you are getting a code. do you have the code number they told you. if the code is for missing after cat 02s then i dont see how that would effect your idle. those 02s are to monitor the catalytic converters. if your in a state that has emissions testing your not going to pass.
  #22
Old 01-26-2012, 09:41 PM
jackss00's Avatar
no they didn't tell me much.Guess ill see what they say tomorrow
  #23
Old 01-27-2012, 05:06 AM
learn as much as you can knowledge is power. here is a list of the po codes for the 02 sensors in a obd2 system
P0030 HO2S Heater Control Circuit (Bank 1 Sensor 1)
• P0031 HO2S Heater Control Circuit Low (Bank 1 Sensor 1)
• P0032 HO2S Heater Control Circuit High (Bank 1 Sensor 1)
• P0033 Turbo Charger Bypass Valve Control Circuit
• P0034 Turbo Charger Bypass Valve Control Circuit Low
• P0035 Turbo Charger Bypass Valve Control Circuit High
• P0036 HO2S Heater Control Circuit (Bank 1 Sensor 2)
• P0037 HO2S Heater Control Circuit Low (Bank 1 Sensor 2)
• P0038 HO2S Heater Control Circuit High (Bank 1 Sensor 2)
• P0039 Turbo/Super Charger Bypass Valve Control Circuit Range/Performance
• P0040 Upstream Oxygen Sensors Swapped From Bank To Bank
• P0041 Downstream Oxygen Sensors Swapped From Bank To Bank
• P0042 HO2S Heater Control Circuit (Bank 1 Sensor 3)
• P0043 HO2S Heater Control Circuit Low (Bank 1 Sensor 3)
• P0044 HO2S Heater Control Circuit High (Bank 1 Sensor 3)
• P0050 HO2S Heater Control Circuit (Bank 2 Sensor 1)
• P0051 HO2S Heater Control Circuit Low (Bank 2 Sensor 1)
• P0052 HO2S Heater Control Circuit High (Bank 2 Sensor 1)
• P0053 HO2S Heater Resistance (Bank 1, Sensor 1)
• P0054 HO2S Heater Resistance (Bank 1, Sensor 2)
• P0055 HO2S Heater Resistance (Bank 1, Sensor 3)
• P0056 HO2S Heater Control Circuit (Bank 2 Sensor 2)
• P0057 HO2S Heater Control Circuit Low (Bank 2 Sensor 2)
• P0058 HO2S Heater Control Circuit High (Bank 2 Sensor 2)
• P0059 HO2S Heater Resistance (Bank 2, Sensor 1)
• P0060 HO2S Heater Resistance (Bank 2, Sensor 2)
• P0061 HO2S Heater Resistance (Bank 2, Sensor 3)
• P0062 HO2S Heater Control Circuit (Bank 2 Sensor 3)
• P0063 HO2S Heater Control Circuit Low (Bank 2 Sensor 3)
• P0064 HO2S Heater Control Circuit High (Bank 2 Sensor 3)
  #24
Old 01-27-2012, 05:22 AM
BasicConcepts's Avatar
Technical User
Originally Posted by craby
learn as much as you can knolage is power. here is a list of the po codes for the 02 sensors in a obd2 system
so is grammar
  #25
Old 01-27-2012, 07:36 AM
fixed, lol, i can say it and know what it means. is that good enough.
  #26
Old 01-28-2012, 02:38 PM
jackss00's Avatar
well i got new o2 sensors and that fixed my idle issue.I went to the shop and they showed me how to use the programmer.
I asked them about the dyno numbers and they said they were accurate and the low numbers were bc it was an auto and im losing 30 percent of power bc of it.They told me some of the other numbers of other cars that were dynod and they all sounded low to me.But they said the guy that comes and does the tuning has a good rep and apparently he is pretty good.
  #27
Old 01-28-2012, 03:35 PM
Technical User
any shiesty business owner will tell you something like that just to squeeze that extra buck out of you (or he really could be good at what he does)
also 30% seems a little high yes the manual gives you more hp and fuel econ (mainly because its easier to turn a manual than an auto) but i dont think youd lose 100hp
  #28
Old 01-28-2012, 04:17 PM
so is grammar
Ehhhhhh, spelling is spelling. Grammar is sentence and paragraph structure. Nice kick in the nuts attempt anyway though! lmao
maudyZ28
06-17-2010 02:30 PM
LeadFarmer
LS Series Tech
16
12-24-2009 09:51 AM
6.5 Detroit TD
09-09-2009 09:16 AM
93Z28joel
08-03-2008 12:29 AM
SpecterGT260
07-10-2008 02:27 PM
Quick Reply: these dyno numbers dont sound right
