Stuck in Park!
Old Oct 17, 2019 | 12:41 PM
blg898's Avatar
Default Stuck in Park!
Hello everyone!
My 97' V6 Camaro has only has 112,000 miles and is in Missouri.
Currently it hasn't been driven since July.
My question is for any way to get it out of Park.
The shift can engage when pushing down the button, but won't move back into Circle Drive.
So far have tried turning the steering wheel and pumping the brake.
Any thoughts?
Old Oct 17, 2019 | 02:16 PM
Have you tried rocking the car while you turn the wheel. If a car moves even a little after its parked and the wheels are turned it can be put a huge bind on the sheeting wheel. You end up with a lot of the weight clamping the steering wheel in place. I drove a flatbed tow truck sometimes my first year as a mechanic and I will bet I un-stuck 6 wheels. Everything from brand new cars to old junkers. On the other hand after 6 year turn wrenches full time I have never seen a steering wheel lockup for any other reason. All failing steering columns I have had to repaired was for being too loose,
Old Oct 17, 2019 | 03:32 PM
blg898's Avatar
I will ask my Father to try, thanks!
The goal is to get the shifter out of Park and into Drive. Please let me know if this will help..
Old Oct 18, 2019 | 12:43 PM
yes it should help
Old Oct 18, 2019 | 04:47 PM
Lakerman62's Avatar
Sometimes the plastic white pin that is inside the shifter breaks cause u not to be push down all the way, take the top section of your console off and poke around, worse case u can get it to shift manually in a pinch until you fix/figure it out, good luck
sgreg831
Nov 15, 2012 05:41 AM
RFxCamaro
Dec 2, 2010 02:31 PM
vashtx
LS Series Tech
12
Aug 27, 2009 05:07 PM
1979RS
70-81 V8 Tech
Feb 20, 2008 07:45 AM
1979RS
Jan 15, 2008 09:37 PM
