Stripped intake thread
Sorry for the link not working, but, if hole is a through hole, you should use Permatex #2 on the bolt(s) for sealing the threads.
Go to: www.grainger.com and look up Helicoil R1185-6
The better Heli-Coil® kits come with drill bits
R1185-6 includes X drill bit, $26 at Grainger
https://www.grainger.com/product/HEL...Query=r-1185-6
DON'T FORGET to break off the install tab at the bottom of coil after installing.
Ok it is a through hole. Ill use the lock to seal the helicoil in and then use the thread seal to prevent leakage? is the blue the #2?
Also i just tried to drill this hole in a minute ago and the 12v cordless drill I have is super weak. I bought an 18v thats charging now but i dont think itll be any stronger. Would a 20v drill work at least? i dont have access to use a drill with a cord
Voltage is not the only factor. Drill amperage and gearing will effect this. I have seen a pretty nice upgrade from 12v to 18v but my 18 was a better drill with hi-low gearing. When I attempt to drill steel with my 18v drill I can feel it flex like the whole structure of the drill is being strained. I don;t think most of the battery operated tools are designed for working with metals. Although aluminum is much less stressful than steel.
A good strong plug in drill should be part of your tool collection unless you have a good air drill. They can be found dirt cheap at yard sales. If you can find a 1/2" GE drill from the 70's you may have to re-cord it but you would have a real drill when done. One that can hurt your wrist.
man i ended up renting a solid battery drill from home depot and it did the trick. I dont know why i have such bad luck with this but i went to knock the tang off and it just kept stretching the darn coil out. I was thinking about just using a 7/16 bolt for the thread size i made and call it a day. Im pretty sure it will fit through the intake. This is all starting to add up lol Thoughts?
