Stock Manifold Questin, need help asap
Old Jun 19, 2008 | 06:28 PM
94z's Avatar
94z
Default Stock Manifold Questin, need help asap
Hey I just hit a rough spot tearing my engine down to rebuild it. The stock manifold bolts that connect to the Y pipe are pretty old looking at look like they are a 15 mm size. Im having probs getting to them and getting them off anyone know of a way to do this without buying a deep well 15 mm sockit?
Old Jun 19, 2008 | 07:42 PM
meteoralp45's Avatar
Default RE: Stock Manifold Questin, need help asap
saws all ftw
Old Jun 19, 2008 | 07:45 PM
02StanGT's Avatar
Spray with WD40, let soak, use impact wrench. If it doesn't break loose rinse, lather, and repeat.
Old Jun 19, 2008 | 08:02 PM
94z's Avatar
94z
alright thanks for the replies, there is just so much limited room up there any ideas on anything i can take out first to make the job easier? maybe the sterring linkage.
Old Jun 19, 2008 | 08:12 PM
02StanGT's Avatar
Removing things to gain access is fine. Just make sure you remember how it goes back together. [&:] If you know anyone with a lift, that would help out tremendously.
Old Jun 19, 2008 | 08:31 PM
94z's Avatar
94z
no lifts unfortunately, i think ill go with the next best thing and buy 2 more jack stands tomarrow so i can jack up the front and that back
Old Jun 19, 2008 | 08:37 PM
02StanGT's Avatar
I'm sure you'll find it easier to deal with from the bottom. Still a tight squeeze, but seems easier to work around to me.
Old Jun 20, 2008 | 12:28 AM
95slvrZ28's Avatar
You can take off the starter, that may make the passenger side a bit easier to access. Instead of WD-40 I recommend Aerokroil, or if you can't find any of that PB-Blaster is the next best thing. When I did my header I twisted off 1/2 of those bolts, so good luck...
Old Jun 20, 2008 | 01:41 AM
musicman2.0's Avatar
PB-Blaster is great stuff, also, use a wrench/socket that is six sided, so you don't strip the head of the bolt. Ratcheting wrenches are wonderful little tools too.
Old Jun 20, 2008 | 04:31 PM
02StanGT's Avatar
ORIGINAL: 95slvrZ28
Thank you, I couldn't think of any other names. WD-40 was the only one I could think of offhand.
