starting problems
starting problems
Hey i am new here, i hyave a 2000 ss that has a crank but no start problem. I have checked codes! none, fuel pressure is 58 at key on. will start once in about every 100 tries thyen runs good till you turn it off then no start again? could I get a little help if any one has experinced this or may be point me in another direction? HELP!
need to find out if the coils are getting power to them. i would say the key may be wearing or ign switch but seems like the vats would show a security light so check the ignition switch. could be the bcm acting up.
