Squeeling noise on start up
Old Jun 5, 2013 | 09:31 PM
Justin Patrick Kelley's Avatar
when you take off the air intake and take off the 3 screws holding the throttle body onto the intake manifold, there are two small holes on the bottom of the manifold. On the right one (facing the engine) gasoline came out of it.
GAS CAME FROM THE BOTTOM RIGHT HOLE, AFTER YOU TAKE OFF THE THROTTLE BODY, ON THE UPPER INTAKE MANIFOLD
I will upload pictures tomorrow, sorry for not being prepared guys!
Old Jun 5, 2013 | 10:56 PM
check your fuel pressure regulator vacumm hose for fuel. should not have gas in it. only way i can think of where gas could get to the tb
Old Jun 5, 2013 | 10:58 PM
And if it has gas in it, I should obviously clean it out. How do I stop fuel from getting into it?
Old Jun 6, 2013 | 01:33 AM
if theres gas in the vacumm hose you need a new fuel pressure regulator.
Old Jun 6, 2013 | 07:16 AM
ok the, fuel pressure regulator vacumm hose and the Fuel Injection Pressure Regulator. Both are the same thing, correct?
Old Jun 6, 2013 | 08:03 AM
Alright here is what I did this morning.
1. I checked the regulator. No gas liquid came from the hose and it did not smell at all of gas.
2. I took off the air intake and throttle body again and took some pictures.
You can see that the gasket fell off and that at the bottom of the upper intake, there are two holes. The one with the rag shoved in it is where I had the leak from.
I took a glass, collected some of what was leaking from this hole and it turned out to be an orange color liquid. It smells strong of gas in the engine from this leak but when I smelt it from the glass, I could smell oil.
Old Jun 6, 2013 | 08:05 AM
also, small problem. Now one of the screws that holds the throttle body to the intake manifold, the hole is stripped.
Old Jun 6, 2013 | 08:06 AM
the vacumm hose goes to the fpr. fpr should be on the passenger side behind the coil pack. should be a small hose going from fpr to the intake manifold. thats the vacumm hose.
Old Jun 6, 2013 | 08:10 AM
i think thats where coolant is feed to the tb to keep it from feezing up in very cold weather.
jayorr42AL
Nov 23, 2014 04:21 AM
jlking84
Jun 23, 2013 01:01 PM
auto
Dec 31, 2010 10:57 PM
Ofallah
Jun 12, 2010 11:46 PM
lottboy
LS Series Tech
Oct 13, 2005 10:40 PM
